[GRASS-QA] GRASS QA: jachym | ./grass6/vector/v.to.db/parse.c |no clones | 0 monsters | 0 warnings
Mon Dec 11 13:03:01 EST 2006
Hello jachym,
ANALYSIS
vector/v.to.db/parse.c functions
parse_command_line (Begins at: 13 Ends at: 159)
Complexity:   |      12 |       |      OK |
CalledNBR:    |      42 |     * |         |
LOC:          |     147 |     * |         |
metrics are OK
parse_units (Begins at: 161 Ends at: 173)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
parse_option (Begins at: 175 Ends at: 192)
CalledNBR:    |      11 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
match (Begins at: 195 Ends at: 203)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-11 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
