[GRASS-QA] GRASS QA: markus | ./grass6/lib/gis/parser.c |1 clones ( parser.c )| 1 monsters | 7 warnings
Tue Dec 12 03:36:18 EST 2006
Hello markus,
ANALYSIS
lib/gis/parser.c functions
G_disable_interactive (Begins at: 200 Ends at: 216)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
G_define_flag (Begins at: 219 Ends at: 267)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      49 |       |      OK |
metrics are OK
G_define_option (Begins at: 270 Ends at: 340)
LOC:          |      71 |       |      OK |
metrics are OK
G_define_standard_option (Begins at: 343 Ends at: 524)
Complexity:   |      22 |     * |         |
CalledNBR:    |      25 |       |      OK |
LOC:          |     182 |     * |         |
metrics are OK
G_define_module (Begins at: 527 Ends at: 561)
CalledNBR:    |       1 |       |      OK |
LOC:          |      35 |       |      OK |
metrics are OK
G_parser (Begins at: 563 Ends at: 820)
Complexity:   |      36 |   *** | MONSTER |
CalledNBR:    |      71 |    ** | Warning |
LOC:          |     258 |    ** | Warning |
at least 3 values are close to an outlier please consider revising code
uses_new_gisprompt (Begins at: 823 Ends at: 868)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      46 |       |      OK |
metrics are OK
G_usage (Begins at: 870 Ends at: 1043)
Complexity:   |      31 |    ** | Warning |
CalledNBR:    |      53 |     * |         |
LOC:          |     174 |     * |         |
at least 1 values are close to an outlier please consider revising code
print_escaped_for_xml (Begins at: 1045 Ends at: 1061)
Complexity:   |       6 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
G_usage_xml (Begins at: 1063 Ends at: 1267)
Complexity:   |      26 |    ** | Warning |
CalledNBR:    |      65 |    ** | Warning |
LOC:          |     205 |    ** | Warning |
G_usage_html (Begins at: 1269 Ends at: 1500)
Complexity:   |      41 |   *** | MONSTER |
CalledNBR:    |      80 |    ** | Warning |
LOC:          |     232 |    ** | Warning |
1 metric are OUT OF RANGE!
generate_tcl (Begins at: 1502 Ends at: 1587)
Complexity:   |      10 |       |      OK |
CalledNBR:    |      33 |       |      OK |
LOC:          |      86 |       |      OK |
metrics are OK
G_gui (Begins at: 1590 Ends at: 1619)
CalledNBR:    |       8 |       |      OK |
LOC:          |      30 |       |      OK |
metrics are OK
G_tcltk (Begins at: 1622 Ends at: 1637)
LOC:          |      16 |       |      OK |
metrics are OK
show_options (Begins at: 1639 Ends at: 1668)
Complexity:   |       4 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      30 |       |      OK |
metrics are OK
show (Begins at: 1670 Ends at: 1683)
CalledNBR:    |       3 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
set_flag (Begins at: 1685 Ends at: 1712)
LOC:          |      28 |       |      OK |
metrics are OK
contains (Begins at: 1717 Ends at: 1726)
LOC:          |      10 |       |      OK |
metrics are OK
set_option (Begins at: 1728 Ends at: 1788)
CalledNBR:    |      13 |       |      OK |
LOC:          |      61 |       |      OK |
metrics are OK
check_opts (Begins at: 1790 Ends at: 1827)
LOC:          |      38 |       |      OK |
metrics are OK
check_an_opt (Begins at: 1829 Ends at: 1871)
ParamNBR:     |       4 |       |      OK |
LOC:          |      43 |       |      OK |
metrics are OK
check_int (Begins at: 1873 Ends at: 1939)
Complexity:   |      13 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      67 |       |      OK |
metrics are OK
check_double (Begins at: 1941 Ends at: 1981)
LOC:          |      41 |       |      OK |
metrics are OK
check_string (Begins at: 1983 Ends at: 2010)
Complexity:   |       8 |       |      OK |
LOC:          |      28 |       |      OK |
metrics are OK
check_required (Begins at: 2012 Ends at: 2035)
LOC:          |      24 |       |      OK |
metrics are OK
split_opts (Begins at: 2037 Ends at: 2100)
LOC:          |      64 |       |      OK |
metrics are OK
check_multiple_opts (Begins at: 2102 Ends at: 2140)
CalledNBR:    |       5 |       |      OK |
LOC:          |      39 |       |      OK |
metrics are OK
check_overwrite (Begins at: 2143 Ends at: 2199)
Complexity:   |      11 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      57 |       |      OK |
metrics are OK
interactive (Begins at: 2201 Ends at: 2229)
LOC:          |      29 |       |      OK |
metrics are OK
interactive_flag (Begins at: 2231 Ends at: 2239)
LOC:          |       9 |       |      OK |
metrics are OK
interactive_option (Begins at: 2241 Ends at: 2331)
Complexity:   |      23 |     * |         |
CalledNBR:    |      41 |     * |         |
LOC:          |      91 |       |      OK |
metrics are OK
split_gisprompt (Begins at: 2333 Ends at: 2363)
LOC:          |      31 |       |      OK |
metrics are OK
gis_prompt (Begins at: 2365 Ends at: 2410)
CalledNBR:    |      20 |       |      OK |
LOC:          |      46 |       |      OK |
metrics are OK
G_recreate_command (Begins at: 2412 Ends at: 2514)
LOC:          |     103 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  interactive_flag
In lib/gis/parser.c clones of  interactive_flag are:
	lib/gis/rm_colr.c  G_remove_colr
Threshold GRASS6 key metrics values at 2006-12-12 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
