[GRASS-QA] GRASS QA: hamish | ./grass6/display/d.frame/list.c |no clones | 0 monsters | 0 warnings
Tue Dec 12 03:36:17 EST 2006
Hello hamish,
ANALYSIS
display/d.frame/list.c functions
main (Begins at: 11 Ends at: 103)
Complexity:   |      15 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      32 |       |      OK |
LOC:          |      93 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-12 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
