[GRASS-QA] GRASS QA: markus | ./grass6/lib/g3d/g3dclose.c |1 clones ( write.c write.c g3dclose.c )| 0 monsters | 0 warnings
Wed Dec 13 10:02:42 EST 2006
Hello markus,
ANALYSIS
lib/g3d/g3dclose.c functions
G3d_closeNew (Begins at: 13 Ends at: 60)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      17 |       |      OK |
LOC:          |      48 |       |      OK |
metrics are OK
G3d_closeCellNew (Begins at: 65 Ends at: 109)
Complexity:   |       8 |       |      OK |
CalledNBR:    |      13 |       |      OK |
LOC:          |      45 |       |      OK |
metrics are OK
G3d_closeOld (Begins at: 114 Ends at: 123)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
G3d_closeCellOld (Begins at: 128 Ends at: 152)
LOC:          |      25 |       |      OK |
metrics are OK
G3d_closeCell (Begins at: 155 Ends at: 204)
LOC:          |      50 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  G3d_closeOld
In lib/g3d/g3dclose.c clones of  G3d_closeOld are:
	raster3d/r3.in.ascii/main.c  fatalError
Threshold GRASS6 key metrics values at 2006-12-13 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
