[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.carve/enforce_ds.c |no clones | 0 monsters | 1 warnings
Wed Dec 13 10:02:42 EST 2006
Hello markus,
ANALYSIS
raster/r.carve/enforce_ds.c functions
enforce_downstream (Begins at: 53 Ends at: 88)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      13 |       |      OK |
LOC:          |      36 |       |      OK |
metrics are OK
process_line (Begins at: 91 Ends at: 202)
Complexity:   |      13 |       |      OK |
CalledNBR:    |      32 |       |      OK |
LOC:          |     112 |       |      OK |
metrics are OK
clear_bitmap (Begins at: 205 Ends at: 212)
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
traverse_line_flat (Begins at: 215 Ends at: 238)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
traverse_line_noflat (Begins at: 241 Ends at: 265)
ParamNBR:     |       4 |       |      OK |
LOC:          |      25 |       |      OK |
metrics are OK
set_min_point (Begins at: 269 Ends at: 295)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |       9 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
lowest_cell_near_point (Begins at: 299 Ends at: 416)
Complexity:   |      25 |     * |         |
CalledNBR:    |      22 |       |      OK |
LOC:          |     118 |     * |         |
metrics are OK
process_line_segment (Begins at: 424 Ends at: 514)
ParamNBR:     |       7 |    ** | Warning |
LOC:          |      91 |       |      OK |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-13 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
