[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.le/r.le.pixel/driver.c |no clones | 5 monsters | 3 warnings
Wed Dec 13 10:02:43 EST 2006
Hello markus,
ANALYSIS
raster/r.le/r.le.pixel/driver.c functions
texture_fore (Begins at: 47 Ends at: 140)
Complexity:   |      13 |       |      OK |
ParamNBR:     |       0 |       |      OK |
CalledNBR:    |      41 |     * |         |
LOC:          |      94 |       |      OK |
metrics are OK
mv_driver (Begins at: 147 Ends at: 1072)
Complexity:   |     167 |   *** | MONSTER |
CalledNBR:    |     356 |   *** | MONSTER |
LOC:          |     926 |   *** | MONSTER |
3 metric are OUT OF RANGE!
set_colors (Begins at: 1074 Ends at: 1091)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
fopen0 (Begins at: 1093 Ends at: 1108)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
fopen1 (Begins at: 1116 Ends at: 1133)
CalledNBR:    |      10 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
fopen2 (Begins at: 1139 Ends at: 1155)
CalledNBR:    |       9 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
fopen3 (Begins at: 1161 Ends at: 1177)
LOC:          |      17 |       |      OK |
metrics are OK
meter2 (Begins at: 1185 Ends at: 1224)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       3 |       |      OK |
LOC:          |      40 |       |      OK |
metrics are OK
read_mwind (Begins at: 1230 Ends at: 1259)
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |      12 |       |      OK |
LOC:          |      30 |       |      OK |
at least 1 values are close to an outlier please consider revising code
unit_driver (Begins at: 1265 Ends at: 1499)
Complexity:   |      42 |   *** | MONSTER |
CalledNBR:    |      69 |    ** | Warning |
LOC:          |     235 |    ** | Warning |
1 metric are OUT OF RANGE!
run_clip (Begins at: 1501 Ends at: 1559)
Complexity:   |       5 |       |      OK |
ParamNBR:     |      10 |   *** | MONSTER |
LOC:          |      59 |       |      OK |
whole_reg_driver (Begins at: 1561 Ends at: 1752)
Complexity:   |      34 |    ** | Warning |
CalledNBR:    |      35 |       |      OK |
LOC:          |     192 |    ** | Warning |
at least 2 values are close to an outlier please consider revising code
get_rich_whole (Begins at: 1754 Ends at: 1779)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      26 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-13 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
