[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.le/r.le.setup/setup.c |no clones | 0 monsters | 3 warnings
Wed Dec 13 10:02:43 EST 2006
Hello markus,
ANALYSIS
raster/r.le/r.le.setup/setup.c functions
change_draw (Begins at: 44 Ends at: 90)
Complexity:   |      15 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      42 |     * |         |
LOC:          |      47 |       |      OK |
metrics are OK
set_map (Begins at: 96 Ends at: 235)
Complexity:   |      14 |       |      OK |
ParamNBR:     |       8 |    ** | Warning |
CalledNBR:    |      41 |     * |         |
LOC:          |     140 |     * |         |
at least 1 values are close to an outlier please consider revising code
paint_map (Begins at: 243 Ends at: 271)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
set_rgn (Begins at: 273 Ends at: 428)
Complexity:   |      19 |     * |         |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      55 |     * |         |
LOC:          |     156 |     * |         |
metrics are OK
set_frame (Begins at: 435 Ends at: 510)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      25 |       |      OK |
LOC:          |      76 |       |      OK |
metrics are OK
ppoint (Begins at: 512 Ends at: 537)
CalledNBR:    |       4 |       |      OK |
LOC:          |      26 |       |      OK |
metrics are OK
pbutton (Begins at: 545 Ends at: 554)
Complexity:   |       1 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
save_rgn (Begins at: 562 Ends at: 634)
CalledNBR:    |      27 |       |      OK |
LOC:          |      73 |       |      OK |
print_hd (Begins at: 636 Ends at: 656)
CalledNBR:    |       6 |       |      OK |
LOC:          |      21 |       |      OK |
metrics are OK
scr_cell (Begins at: 658 Ends at: 671)
ParamNBR:     |       6 |     * |         |
CalledNBR:    |       0 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
change_color (Begins at: 673 Ends at: 780)
Complexity:   |      20 |     * |         |
CalledNBR:    |      63 |    ** | Warning |
LOC:          |     108 |       |      OK |
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-13 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
