[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.clump/clump.c |no clones | 0 monsters | 1 warnings
Wed Dec 13 10:02:42 EST 2006
Hello markus,
ANALYSIS
raster/r.clump/clump.c functions
clump (Begins at: 27 Ends at: 266)
Complexity:   |      22 |     * |         |
CalledNBR:    |      27 |       |      OK |
LOC:          |     240 |    ** | Warning |
at least 1 values are close to an outlier please consider revising code
print_time (Begins at: 269 Ends at: 291)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      23 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-13 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
