[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.random/random.c |no clones | 0 monsters | 2 warnings
Wed Dec 13 10:02:44 EST 2006
Hello markus,
ANALYSIS
raster/r.random/random.c functions
execute_random (Begins at: 12 Ends at: 203)
Complexity:   |      25 |     * |         |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      77 |    ** | Warning |
LOC:          |     192 |    ** | Warning |
at least 2 values are close to an outlier please consider revising code
cpvalue (Begins at: 206 Ends at: 218)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
cell_as_dbl (Begins at: 220 Ends at: 231)
LOC:          |      12 |       |      OK |
metrics are OK
set_to_null (Begins at: 234 Ends at: 245)
CalledNBR:    |       3 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
is_null_value (Begins at: 248 Ends at: 265)
LOC:          |      18 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-13 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
