[GRASS-QA] GRASS QA: markus | ./grass6/lib/gis/reclass.c |no clones | 0 monsters | 0 warnings
Wed Dec 13 10:37:31 EST 2006
Hello markus,
ANALYSIS
lib/gis/reclass.c functions
G_is_reclass (Begins at: 30 Ends at: 63)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      34 |       |      OK |
metrics are OK
G_is_reclassed_to (Begins at: 65 Ends at: 125)
Complexity:   |      10 |       |      OK |
CalledNBR:    |      12 |       |      OK |
LOC:          |      61 |       |      OK |
metrics are OK
G_get_reclass (Begins at: 127 Ends at: 165)
Complexity:   |       8 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      39 |       |      OK |
metrics are OK
G_free_reclass (Begins at: 167 Ends at: 181)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      15 |       |      OK |
metrics are OK
reclass_type (Begins at: 183 Ends at: 217)
CalledNBR:    |       8 |       |      OK |
LOC:          |      35 |       |      OK |
metrics are OK
fopen_cellhd_old (Begins at: 219 Ends at: 222)
Complexity:   |       1 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
G_put_reclass (Begins at: 224 Ends at: 325)
Complexity:   |      15 |       |      OK |
CalledNBR:    |      33 |       |      OK |
LOC:          |     102 |       |      OK |
metrics are OK
fopen_cellhd_new (Begins at: 327 Ends at: 330)
LOC:          |       4 |       |      OK |
metrics are OK
get_reclass_table (Begins at: 332 Ends at: 382)
LOC:          |      51 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-13 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
