[GRASS-QA] GRASS QA: markus | ./grass6/raster3d/r3.cross.rast/main.c |no clones | 0 monsters | 1 warnings
Wed Dec 13 10:37:32 EST 2006
Hello markus,
ANALYSIS
raster3d/r3.cross.rast/main.c functions
fatal_error (Begins at: 48 Ends at: 68)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      21 |       |      OK |
metrics are OK
close_output_map (Begins at: 74 Ends at: 78)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
set_params (Begins at: 84 Ends at: 111)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       0 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      28 |       |      OK |
metrics are OK
rast3d_cross_section (Begins at: 118 Ends at: 247)
Complexity:   |      23 |     * |         |
CalledNBR:    |      30 |       |      OK |
LOC:          |     130 |     * |         |
metrics are OK
main (Begins at: 253 Ends at: 402)
CalledNBR:    |      62 |    ** | Warning |
LOC:          |     150 |     * |         |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-13 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
