[GRASS-QA] GRASS QA: markus | ./grass6/lib/imagery/group.c |no clones | 0 monsters | 0 warnings
Wed Dec 13 10:37:31 EST 2006
Hello markus,
ANALYSIS
lib/imagery/group.c functions
I_get_group (Begins at: 22 Ends at: 36)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      15 |       |      OK |
metrics are OK
I_put_group (Begins at: 39 Ends at: 49)
CalledNBR:    |       3 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
I_get_subgroup (Begins at: 52 Ends at: 69)
Complexity:   |       3 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
I_put_subgroup (Begins at: 72 Ends at: 98)
CalledNBR:    |       4 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
I_get_group_ref (Begins at: 100 Ends at: 120)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      21 |       |      OK |
metrics are OK
I_get_subgroup_ref (Begins at: 122 Ends at: 128)
ParamNBR:     |       3 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
get_ref (Begins at: 130 Ends at: 168)
Complexity:   |       6 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      39 |       |      OK |
metrics are OK
set_color (Begins at: 170 Ends at: 194)
Complexity:   |      14 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      25 |       |      OK |
metrics are OK
I_init_ref_color_nums (Begins at: 196 Ends at: 252)
Complexity:   |       8 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      57 |       |      OK |
metrics are OK
I_put_group_ref (Begins at: 254 Ends at: 274)
LOC:          |      21 |       |      OK |
metrics are OK
I_put_subgroup_ref (Begins at: 276 Ends at: 279)
LOC:          |       4 |       |      OK |
metrics are OK
put_ref (Begins at: 281 Ends at: 332)
Complexity:   |       7 |       |      OK |
CalledNBR:    |       9 |       |      OK |
LOC:          |      52 |       |      OK |
metrics are OK
I_add_file_to_group_ref (Begins at: 334 Ends at: 379)
LOC:          |      46 |       |      OK |
metrics are OK
I_transfer_group_ref_file (Begins at: 381 Ends at: 413)
Complexity:   |       4 |       |      OK |
LOC:          |      33 |       |      OK |
metrics are OK
I_init_group_ref (Begins at: 415 Ends at: 432)
LOC:          |      18 |       |      OK |
metrics are OK
I_free_group_ref (Begins at: 434 Ends at: 441)
LOC:          |       8 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-13 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
