[GRASS-QA] GRASS QA: markus | ./grass6/raster3d/r3.in.v5d/main.c |no clones | 0 monsters | 0 warnings
Wed Dec 13 10:37:32 EST 2006
Hello markus,
ANALYSIS
raster3d/r3.in.v5d/main.c functions
fatalError (Begins at: 46 Ends at: 54)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
setParams (Begins at: 65 Ends at: 90)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       0 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      26 |       |      OK |
metrics are OK
getParams (Begins at: 95 Ends at: 104)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       4 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
convert (Begins at: 108 Ends at: 181)
Complexity:   |       5 |       |      OK |
CalledNBR:    |      12 |       |      OK |
LOC:          |      74 |       |      OK |
metrics are OK
main (Begins at: 186 Ends at: 228)
CalledNBR:    |      16 |       |      OK |
LOC:          |      43 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-13 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
