[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.drain/tinf.c |1 clones ( alloc.c cats.c color_read.c find_cell.c get_row.c opencell.c range.c ps_outline.c main.c main.c tinf.c )| 0 monsters | 0 warnings
Wed Dec 13 10:37:33 EST 2006
Hello markus,
ANALYSIS
raster/r.drain/tinf.c functions
set_func_pointers (Begins at: 13 Ends at: 76)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      64 |       |      OK |
metrics are OK
is_null_c (Begins at: 79 Ends at: 79)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       1 |       |      OK |
metrics are OK
is_null_f (Begins at: 80 Ends at: 80)
LOC:          |       1 |       |      OK |
metrics are OK
is_null_d (Begins at: 81 Ends at: 81)
LOC:          |       1 |       |      OK |
metrics are OK
set_null_value_c (Begins at: 84 Ends at: 84)
LOC:          |       1 |       |      OK |
metrics are OK
set_null_value_f (Begins at: 85 Ends at: 85)
LOC:          |       1 |       |      OK |
metrics are OK
set_null_value_d (Begins at: 86 Ends at: 86)
LOC:          |       1 |       |      OK |
metrics are OK
bpe_c (Begins at: 89 Ends at: 89)
ParamNBR:     |       0 |       |      OK |
LOC:          |       1 |       |      OK |
metrics are OK
bpe_f (Begins at: 90 Ends at: 90)
LOC:          |       1 |       |      OK |
metrics are OK
bpe_d (Begins at: 91 Ends at: 91)
LOC:          |       1 |       |      OK |
metrics are OK
get_min_c (Begins at: 94 Ends at: 101)
Complexity:   |       2 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
get_min_f (Begins at: 103 Ends at: 110)
LOC:          |       8 |       |      OK |
metrics are OK
get_min_d (Begins at: 112 Ends at: 119)
LOC:          |       8 |       |      OK |
metrics are OK
get_max_c (Begins at: 122 Ends at: 129)
LOC:          |       8 |       |      OK |
metrics are OK
get_max_f (Begins at: 131 Ends at: 138)
LOC:          |       8 |       |      OK |
metrics are OK
get_max_d (Begins at: 140 Ends at: 147)
LOC:          |       8 |       |      OK |
metrics are OK
get_row_c (Begins at: 150 Ends at: 153)
ParamNBR:     |       3 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
get_row_f (Begins at: 155 Ends at: 158)
LOC:          |       4 |       |      OK |
metrics are OK
get_row_d (Begins at: 160 Ends at: 163)
LOC:          |       4 |       |      OK |
metrics are OK
put_row_c (Begins at: 166 Ends at: 169)
LOC:          |       4 |       |      OK |
metrics are OK
put_row_f (Begins at: 171 Ends at: 174)
LOC:          |       4 |       |      OK |
metrics are OK
put_row_d (Begins at: 176 Ends at: 179)
LOC:          |       4 |       |      OK |
metrics are OK
get_buf_c (Begins at: 182 Ends at: 185)
LOC:          |       4 |       |      OK |
metrics are OK
get_buf_f (Begins at: 187 Ends at: 190)
LOC:          |       4 |       |      OK |
metrics are OK
get_buf_d (Begins at: 192 Ends at: 195)
LOC:          |       4 |       |      OK |
metrics are OK
set_min_c (Begins at: 198 Ends at: 198)
LOC:          |       1 |       |      OK |
metrics are OK
set_min_f (Begins at: 199 Ends at: 199)
LOC:          |       1 |       |      OK |
metrics are OK
set_min_d (Begins at: 200 Ends at: 200)
LOC:          |       1 |       |      OK |
metrics are OK
set_max_c (Begins at: 203 Ends at: 203)
LOC:          |       1 |       |      OK |
metrics are OK
set_max_f (Begins at: 204 Ends at: 204)
LOC:          |       1 |       |      OK |
metrics are OK
set_max_d (Begins at: 205 Ends at: 205)
LOC:          |       1 |       |      OK |
metrics are OK
diff_c (Begins at: 208 Ends at: 208)
LOC:          |       1 |       |      OK |
metrics are OK
diff_f (Begins at: 209 Ends at: 209)
LOC:          |       1 |       |      OK |
metrics are OK
diff_d (Begins at: 210 Ends at: 210)
LOC:          |       1 |       |      OK |
metrics are OK
sum_c (Begins at: 213 Ends at: 213)
LOC:          |       1 |       |      OK |
metrics are OK
sum_f (Begins at: 214 Ends at: 214)
LOC:          |       1 |       |      OK |
metrics are OK
sum_d (Begins at: 215 Ends at: 215)
LOC:          |       1 |       |      OK |
metrics are OK
quot_c (Begins at: 218 Ends at: 218)
LOC:          |       1 |       |      OK |
metrics are OK
quot_f (Begins at: 219 Ends at: 219)
LOC:          |       1 |       |      OK |
metrics are OK
quot_d (Begins at: 220 Ends at: 220)
LOC:          |       1 |       |      OK |
metrics are OK
prod_c (Begins at: 223 Ends at: 223)
LOC:          |       1 |       |      OK |
metrics are OK
prod_f (Begins at: 224 Ends at: 224)
LOC:          |       1 |       |      OK |
metrics are OK
prod_d (Begins at: 225 Ends at: 225)
LOC:          |       1 |       |      OK |
metrics are OK
slope_c (Begins at: 229 Ends at: 241)
CalledNBR:    |       2 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
slope_f (Begins at: 243 Ends at: 255)
LOC:          |      13 |       |      OK |
metrics are OK
slope_d (Begins at: 257 Ends at: 269)
LOC:          |      13 |       |      OK |
metrics are OK
advance_band3 (Begins at: 273 Ends at: 285)
LOC:          |      13 |       |      OK |
metrics are OK
retreat_band3 (Begins at: 289 Ends at: 305)
LOC:          |      17 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  retreat_band3
In raster/r.drain/tinf.c clones of  retreat_band3 are:
	raster/r.fill.dir/tinf.c  retreat_band3
Threshold GRASS6 key metrics values at 2006-12-13 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
