[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.carve/vect.c |1 clones ( vect.c )| 0 monsters | 0 warnings
Wed Dec 13 11:22:20 EST 2006
Hello markus,
ANALYSIS
raster/r.carve/vect.c functions
open_new_vect (Begins at: 27 Ends at: 35)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
close_vect (Begins at: 41 Ends at: 50)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  open_new_vect
In raster/r.carve/vect.c clones of  open_new_vect are:
	vector/v.buffer/main.c  stop
Threshold GRASS6 key metrics values at 2006-12-13 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
