[GRASS-QA] GRASS QA: markus | ./grass6/lib/gis/wind_overlap.c |no clones | 0 monsters | 0 warnings
Wed Dec 13 11:41:49 EST 2006
Hello markus,
ANALYSIS
lib/gis/wind_overlap.c functions
G_window_overlap (Begins at: 11 Ends at: 45)
Complexity:   |       8 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |       0 |       |      OK |
LOC:          |      35 |       |      OK |
metrics are OK
G_window_percentage_overlap (Begins at: 47 Ends at: 97)
Complexity:   |      16 |     * |         |
LOC:          |      51 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-13 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
