[GRASS-QA] GRASS QA: markus | ./grass6/vector/v.out.dxf/main.c |no clones | 0 monsters | 0 warnings
Wed Dec 13 11:41:49 EST 2006
Hello markus,
ANALYSIS
vector/v.out.dxf/main.c functions
main (Begins at: 35 Ends at: 91)
Complexity:   |       4 |       |      OK |
CalledNBR:    |      27 |       |      OK |
LOC:          |      57 |       |      OK |
metrics are OK
do_limits (Begins at: 93 Ends at: 110)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
make_layername (Begins at: 112 Ends at: 132)
Complexity:   |       1 |       |      OK |
CalledNBR:    |      14 |       |      OK |
LOC:          |      21 |       |      OK |
metrics are OK
add_plines (Begins at: 134 Ends at: 191)
Complexity:   |       6 |       |      OK |
CalledNBR:    |      12 |       |      OK |
LOC:          |      58 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-13 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
