[GRASS-QA] GRASS QA: markus | ./grass6/display/d.what.vect/openvect.c |no clones | 0 monsters | 0 warnings
Wed Dec 13 11:41:48 EST 2006
Hello markus,
ANALYSIS
display/d.what.vect/openvect.c functions
openvect (Begins at: 5 Ends at: 14)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-13 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
