[GRASS-QA] GRASS QA: markus | ./grass6/vector/v.what/main.c |no clones | 0 monsters | 0 warnings
Wed Dec 13 11:41:50 EST 2006
Hello markus,
ANALYSIS
vector/v.what/main.c functions
main (Begins at: 37 Ends at: 211)
Complexity:   |      18 |     * |         |
CalledNBR:    |      54 |     * |         |
LOC:          |     175 |     * |         |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-13 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
