[GRASS-QA] GRASS QA: markus | ./grass6/ps/ps.map/do_vectors.c |no clones | 0 monsters | 0 warnings
Wed Dec 13 12:03:53 EST 2006
Hello markus,
ANALYSIS
ps/ps.map/do_vectors.c functions
do_vectors (Begins at: 18 Ends at: 110)
Complexity:   |      19 |     * |         |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      30 |       |      OK |
LOC:          |      93 |       |      OK |
metrics are OK
do_vpoints (Begins at: 113 Ends at: 149)
Complexity:   |       8 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      37 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-13 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
