[GRASS-QA] GRASS QA: markus | ./grass6/lib/db/dbmi_driver/d_mkdir.c |no clones | 0 monsters | 0 warnings
Thu Dec 14 12:40:26 EST 2006
Hello markus,
ANALYSIS
lib/db/dbmi_driver/d_mkdir.c functions
db_driver_mkdir (Begins at: 20 Ends at: 29)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
make_dir (Begins at: 35 Ends at: 51)
CalledNBR:    |       3 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
make_parent_dir (Begins at: 55 Ends at: 84)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      30 |       |      OK |
metrics are OK
rfind (Begins at: 88 Ends at: 101)
CalledNBR:    |       0 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-14 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
