[GRASS-QA] GRASS QA: markus | ./grass6/lib/gis/user_config.c |no clones | 0 monsters | 0 warnings
Thu Dec 14 12:40:27 EST 2006
Hello markus,
ANALYSIS
lib/gis/user_config.c functions
_make_toplevel (Begins at: 53 Ends at: 161)
Complexity:   |       8 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      16 |       |      OK |
LOC:          |     109 |       |      OK |
metrics are OK
_elem_count_split (Begins at: 164 Ends at: 203)
Complexity:   |       4 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      40 |       |      OK |
metrics are OK
_make_sublevels (Begins at: 206 Ends at: 307)
Complexity:   |       9 |       |      OK |
CalledNBR:    |      25 |       |      OK |
LOC:          |     102 |       |      OK |
metrics are OK
G_rc_path (Begins at: 310 Ends at: 347)
CalledNBR:    |      14 |       |      OK |
LOC:          |      38 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-14 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
