[GRASS-QA] GRASS QA: markus | ./grass6/display/drivers/XDRIVER/Serve_Xevent.c |no clones | 0 monsters | 0 warnings
Thu Dec 14 14:37:08 EST 2006
Hello markus,
ANALYSIS
display/drivers/XDRIVER/Serve_Xevent.c functions
get_xevent (Begins at: 27 Ends at: 58)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      16 |       |      OK |
LOC:          |      32 |       |      OK |
metrics are OK
service_xevent (Begins at: 60 Ends at: 102)
Complexity:   |       8 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       9 |       |      OK |
LOC:          |      43 |       |      OK |
metrics are OK
_time_stamp (Begins at: 104 Ends at: 109)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
check_redraw_process (Begins at: 111 Ends at: 138)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      28 |       |      OK |
metrics are OK
list_push (Begins at: 140 Ends at: 146)
CalledNBR:    |       2 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
list_copy (Begins at: 148 Ends at: 154)
Complexity:   |       2 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
list_free (Begins at: 156 Ends at: 164)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
spawn_redraw_process (Begins at: 166 Ends at: 236)
CalledNBR:    |      23 |       |      OK |
LOC:          |      71 |       |      OK |
metrics are OK
handle_resize_event (Begins at: 238 Ends at: 302)
CalledNBR:    |      25 |       |      OK |
LOC:          |      65 |       |      OK |
metrics are OK
check_flush (Begins at: 304 Ends at: 328)
Complexity:   |       4 |       |      OK |
LOC:          |      25 |       |      OK |
metrics are OK
set_title_busy (Begins at: 330 Ends at: 366)
CalledNBR:    |      11 |       |      OK |
LOC:          |      37 |       |      OK |
metrics are OK
set_busy (Begins at: 368 Ends at: 378)
CalledNBR:    |       4 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-14 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
