[GRASS-QA] GRASS QA: brad | ./grass6/raster/r.sun/main.c |no clones | 3 monsters | 3 warnings
Fri Dec 15 03:48:10 EST 2006
Hello brad,
ANALYSIS
raster/r.sun/main.c functions
main (Begins at: 132 Ends at: 470)
Complexity:   |      24 |     * |         |
CalledNBR:    |     111 |   *** | MONSTER |
LOC:          |     339 |   *** | MONSTER |
2 metric are OUT OF RANGE!
INPUT (Begins at: 473 Ends at: 692)
Complexity:   |      45 |   *** | MONSTER |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      81 |    ** | Warning |
LOC:          |     220 |    ** | Warning |
1 metric are OUT OF RANGE!
OUTGR (Begins at: 694 Ends at: 824)
Complexity:   |      29 |    ** | Warning |
CalledNBR:    |      50 |     * |         |
LOC:          |     131 |     * |         |
at least 1 values are close to an outlier please consider revising code
com_par_const (Begins at: 827 Ends at: 864)
Complexity:   |       6 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      38 |       |      OK |
metrics are OK
com_par (Begins at: 867 Ends at: 938)
Complexity:   |       8 |       |      OK |
CalledNBR:    |      13 |       |      OK |
LOC:          |      72 |       |      OK |
metrics are OK
lumcline2 (Begins at: 942 Ends at: 980)
Complexity:   |       7 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      39 |       |      OK |
metrics are OK
joules2 (Begins at: 982 Ends at: 1112)
Complexity:   |      22 |     * |         |
CalledNBR:    |      11 |       |      OK |
LOC:          |     131 |     * |         |
metrics are OK
new_point (Begins at: 1117 Ends at: 1126)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
where_is_point (Begins at: 1128 Ends at: 1153)
LOC:          |      26 |       |      OK |
metrics are OK
cube (Begins at: 1155 Ends at: 1160)
LOC:          |       6 |       |      OK |
metrics are OK
searching (Begins at: 1162 Ends at: 1188)
CalledNBR:    |       3 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
calculate (Begins at: 1194 Ends at: 1431)
CalledNBR:    |      53 |     * |         |
LOC:          |     238 |    ** | Warning |
at least 2 values are close to an outlier please consider revising code
com_sol_const (Begins at: 1433 Ends at: 1442)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
com_declin (Begins at: 1445 Ends at: 1455)
LOC:          |      11 |       |      OK |
metrics are OK
brad (Begins at: 1457 Ends at: 1484)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      28 |       |      OK |
metrics are OK
drad (Begins at: 1486 Ends at: 1540)
LOC:          |      55 |       |      OK |
metrics are OK
test (Begins at: 1542 Ends at: 1556)
LOC:          |      15 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-15 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
