[GRASS-QA] GRASS QA: brad | ./grass6/raster/r.neighbors/main.c |no clones | 0 monsters | 2 warnings
Fri Dec 15 03:56:43 EST 2006
Hello brad,
ANALYSIS
raster/r.neighbors/main.c functions
main (Begins at: 43 Ends at: 279)
Complexity:   |      21 |     * |         |
CalledNBR:    |      78 |    ** | Warning |
LOC:          |     237 |    ** | Warning |
at least 2 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-15 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
