[GRASS-QA] GRASS QA: brad | ./grass6/raster/r.what/main.c |no clones | 2 monsters | 0 warnings
Fri Dec 15 04:03:59 EST 2006
Hello brad,
ANALYSIS
raster/r.what/main.c functions
main (Begins at: 30 Ends at: 378)
Complexity:   |      44 |   *** | MONSTER |
CalledNBR:    |      79 |    ** | Warning |
LOC:          |     349 |   *** | MONSTER |
2 metric are OUT OF RANGE!
oops (Begins at: 384 Ends at: 400)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
by_row (Begins at: 408 Ends at: 412)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
by_point (Begins at: 420 Ends at: 424)
LOC:          |       5 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-15 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
