[GRASS-QA] GRASS QA: brad | ./grass6/raster/r.reclass/reclass.c |no clones | 0 monsters | 0 warnings
Fri Dec 15 04:12:35 EST 2006
Hello brad,
ANALYSIS
raster/r.reclass/reclass.c functions
compose (Begins at: 9 Ends at: 67)
Complexity:   |       9 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      59 |       |      OK |
metrics are OK
init_reclass (Begins at: 69 Ends at: 118)
Complexity:   |       8 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      50 |       |      OK |
metrics are OK
init_table (Begins at: 120 Ends at: 140)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      21 |       |      OK |
metrics are OK
fill_table (Begins at: 142 Ends at: 154)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
set_cats (Begins at: 156 Ends at: 178)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      23 |       |      OK |
metrics are OK
_reclass (Begins at: 180 Ends at: 191)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
re_reclass (Begins at: 193 Ends at: 207)
ParamNBR:     |       6 |     * |         |
LOC:          |      15 |       |      OK |
metrics are OK
reclass (Begins at: 209 Ends at: 276)
Complexity:   |       7 |       |      OK |
CalledNBR:    |      32 |       |      OK |
LOC:          |      68 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-15 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
