[GRASS-QA] GRASS QA: brad | ./grass6/raster/r.thin/io.c |no clones | 0 monsters | 0 warnings
Fri Dec 15 04:28:18 EST 2006
Hello brad,
ANALYSIS
raster/r.thin/io.c functions
get_a_row (Begins at: 56 Ends at: 63)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
put_a_row (Begins at: 65 Ends at: 71)
Complexity:   |       1 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
read_row (Begins at: 74 Ends at: 78)
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
write_row (Begins at: 80 Ends at: 84)
LOC:          |       5 |       |      OK |
metrics are OK
open_file (Begins at: 86 Ends at: 168)
Complexity:   |       8 |       |      OK |
CalledNBR:    |      41 |     * |         |
LOC:          |      83 |       |      OK |
metrics are OK
close_file (Begins at: 171 Ends at: 204)
Complexity:   |       3 |       |      OK |
CalledNBR:    |      17 |       |      OK |
LOC:          |      34 |       |      OK |
metrics are OK
map_size (Begins at: 207 Ends at: 214)
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-15 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
