[GRASS-QA] GRASS QA: brad | ./grass6/raster/r.surf.area/main.c |no clones | 0 monsters | 0 warnings
Fri Dec 15 04:45:51 EST 2006
Hello brad,
ANALYSIS
raster/r.surf.area/main.c functions
main (Begins at: 71 Ends at: 181)
Complexity:   |       6 |       |      OK |
CalledNBR:    |      38 |     * |         |
LOC:          |     111 |       |      OK |
metrics are OK
add_row_area (Begins at: 186 Ends at: 268)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |      12 |       |      OK |
LOC:          |      83 |       |      OK |
metrics are OK
add_null_area (Begins at: 273 Ends at: 282)
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
v3cross (Begins at: 287 Ends at: 293)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
v3mag (Begins at: 298 Ends at: 302)
LOC:          |       5 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-15 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
