[GRASS-QA] GRASS QA: markus | ./grass6/display/d.rast.edit/edit.c |1 clones ( edit.c )| 1 monsters | 0 warnings
Fri Dec 15 05:35:15 EST 2006
Hello markus,
ANALYSIS
display/d.rast.edit/edit.c functions
edit (Begins at: 22 Ends at: 315)
Complexity:   |      24 |     * |         |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      82 |    ** | Warning |
LOC:          |     294 |   *** | MONSTER |
1 metric are OUT OF RANGE!
edit_mouse_info (Begins at: 317 Ends at: 329)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
edit_mouse_info2 (Begins at: 331 Ends at: 364)
Complexity:   |       3 |       |      OK |
CalledNBR:    |      18 |       |      OK |
LOC:          |      34 |       |      OK |
metrics are OK
use_mouse (Begins at: 367 Ends at: 376)
CalledNBR:    |       5 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  use_mouse
In display/d.rast.edit/edit.c clones of  use_mouse are:
	imagery/i.class/signature.c  write_signatures
Threshold GRASS6 key metrics values at 2006-12-15 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
