[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.cross/cross.c |no clones | 0 monsters | 0 warnings
Fri Dec 15 05:35:17 EST 2006
Hello markus,
ANALYSIS
raster/r.cross/cross.c functions
cross (Begins at: 24 Ends at: 192)
Complexity:   |      21 |     * |         |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      20 |       |      OK |
LOC:          |     169 |     * |         |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-15 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
