[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.thin/thin_lines.c |no clones | 0 monsters | 0 warnings
Fri Dec 15 05:35:17 EST 2006
Hello markus,
ANALYSIS
raster/r.thin/thin_lines.c functions
thin_lines (Begins at: 33 Ends at: 174)
Complexity:   |      12 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      20 |       |      OK |
LOC:          |     142 |     * |         |
metrics are OK
encode_neighbours (Begins at: 180 Ends at: 193)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |       0 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
print_bin (Begins at: 196 Ends at: 207)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-15 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
