[GRASS-QA] GRASS QA: markus | ./grass6/ps/ps.map/ps_outline.c |4 clones ( color_get.c ps_outline.c )| 0 monsters | 0 warnings
Fri Dec 15 05:48:12 EST 2006
Hello markus,
ANALYSIS
ps/ps.map/ps_outline.c functions
ps_outline (Begins at: 38 Ends at: 60)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       9 |       |      OK |
LOC:          |      23 |       |      OK |
metrics are OK
read_outline (Begins at: 72 Ends at: 113)
Complexity:   |       8 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      42 |       |      OK |
metrics are OK
draw_outline (Begins at: 119 Ends at: 153)
CalledNBR:    |      14 |       |      OK |
LOC:          |      35 |       |      OK |
metrics are OK
draw_boundaries (Begins at: 157 Ends at: 163)
CalledNBR:    |       4 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
read_next (Begins at: 167 Ends at: 175)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
o_alloc_bufs (Begins at: 180 Ends at: 186)
CalledNBR:    |       2 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
draw_top (Begins at: 189 Ends at: 203)
Complexity:   |       2 |       |      OK |
LOC:          |      15 |       |      OK |
metrics are OK
draw_rite (Begins at: 206 Ends at: 220)
LOC:          |      15 |       |      OK |
metrics are OK
draw_left (Begins at: 223 Ends at: 237)
LOC:          |      15 |       |      OK |
metrics are OK
draw_bot (Begins at: 240 Ends at: 254)
LOC:          |      15 |       |      OK |
metrics are OK
Clone analysis:
This file has 4 potentially cloned functions:
  draw_bot  draw_left  draw_rite  draw_top
In ps/ps.map/ps_outline.c clones of  draw_rite are:
	ps/ps.map/ps_outline.c  draw_bot
	ps/ps.map/ps_outline.c  draw_left
	ps/ps.map/ps_outline.c  draw_top
In ps/ps.map/ps_outline.c clones of  draw_left are:
	ps/ps.map/ps_outline.c  draw_rite
In ps/ps.map/ps_outline.c clones of  draw_top are:
In ps/ps.map/ps_outline.c clones of  draw_bot are:
Threshold GRASS6 key metrics values at 2006-12-15 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
