[GRASS-QA] GRASS QA: brad | ./grass6/lib/gis/commas.c |no clones |
0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon Dec 18 03:26:01 EST 2006
Hello brad,
ANALYSIS
lib/gis/commas.c functions
G_insert_commas (Begins at: 12 Ends at: 47)
Complexity: | 9 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 36 | | OK |
metrics are OK
G_remove_commas (Begins at: 55 Ends at: 65)
Complexity: | 2 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 11 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-12-18 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
