[GRASS-QA] GRASS QA: brad | ./grass6/lib/gis/distance.c |no clones | 0 monsters | 1 warnings
Mon Dec 18 03:26:02 EST 2006
Hello brad,
ANALYSIS
lib/gis/distance.c functions
G_begin_distance_calculations (Begins at: 28 Ends at: 64)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       0 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      37 |       |      OK |
metrics are OK
G_distance (Begins at: 66 Ends at: 74)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
G_distance_between_line_segments (Begins at: 77 Ends at: 97)
ParamNBR:     |       8 |    ** | Warning |
CalledNBR:    |       6 |       |      OK |
LOC:          |      21 |       |      OK |
at least 1 values are close to an outlier please consider revising code
G_distance_point_to_line_segment (Begins at: 100 Ends at: 148)
Complexity:   |       8 |       |      OK |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |      10 |       |      OK |
LOC:          |      49 |       |      OK |
metrics are OK
dabs (Begins at: 150 Ends at: 153)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
min4 (Begins at: 155 Ends at: 158)
CalledNBR:    |       3 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
min2 (Begins at: 160 Ends at: 163)
LOC:          |       4 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-18 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
