[GRASS-QA] GRASS QA: brad | ./grass6/lib/gis/tempfile.c |no clones | 0 monsters | 0 warnings
Mon Dec 18 03:26:04 EST 2006
Hello brad,
ANALYSIS
lib/gis/tempfile.c functions
G_tempfile (Begins at: 49 Ends at: 52)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
G__tempfile (Begins at: 54 Ends at: 73)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      20 |       |      OK |
metrics are OK
G__temp_element (Begins at: 75 Ends at: 89)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      15 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-18 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
