[GRASS-QA] GRASS QA: brad | ./grass6/lib/gis/wind_scan.c |no clones | 0 monsters | 0 warnings
Mon Dec 18 03:26:05 EST 2006
Hello brad,
ANALYSIS
lib/gis/wind_scan.c functions
G_scan_northing (Begins at: 17 Ends at: 41)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      25 |       |      OK |
metrics are OK
G_scan_easting (Begins at: 43 Ends at: 71)
Complexity:   |       6 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
G_scan_resolution (Begins at: 73 Ends at: 81)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
scan_double (Begins at: 83 Ends at: 103)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      21 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-18 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
