[GRASS-QA] GRASS QA: brad | ./grass6/lib/gis/view.c |no clones | 2 monsters | 0 warnings
Mon Dec 18 03:26:04 EST 2006
Hello brad,
ANALYSIS
lib/gis/view.c functions
G_3dview_warning (Begins at: 34 Ends at: 39)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
G_get_3dview_defaults (Begins at: 44 Ends at: 152)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |     109 |       |      OK |
metrics are OK
G_put_3dview (Begins at: 154 Ends at: 234)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      45 |     * |         |
LOC:          |      81 |       |      OK |
metrics are OK
G_get_3dview (Begins at: 236 Ends at: 486)
Complexity:   |      47 |   *** | MONSTER |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |     105 |   *** | MONSTER |
LOC:          |     251 |    ** | Warning |
2 metric are OUT OF RANGE!
compare_wind (Begins at: 488 Ends at: 518)
Complexity:   |       6 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      31 |       |      OK |
metrics are OK
get_bool (Begins at: 523 Ends at: 530)
CalledNBR:    |       1 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
pr_winerr (Begins at: 535 Ends at: 553)
Complexity:   |       4 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      19 |       |      OK |
metrics are OK
edge_sort (Begins at: 558 Ends at: 572)
LOC:          |      15 |       |      OK |
metrics are OK
read_old_format (Begins at: 577 Ends at: 635)
Complexity:   |      13 |       |      OK |
CalledNBR:    |      38 |     * |         |
LOC:          |      59 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-18 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
