[GRASS-QA] GRASS QA: markus | ./grass6/lib/db/dbmi_client/start.c |no clones | 1 monsters | 0 warnings
Mon Dec 18 06:01:30 EST 2006
Hello markus,
ANALYSIS
lib/db/dbmi_client/start.c functions
db_start_driver (Begins at: 25 Ends at: 298)
Complexity:   |      15 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      51 |     * |         |
LOC:          |     274 |   *** | MONSTER |
1 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-18 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
