[GRASS-QA] GRASS QA: glynn | ./grass6/general/g.setproj/proj.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon Dec 18 13:20:23 EST 2006
Hello glynn,
ANALYSIS
general/g.setproj/proj.c functions
get_proj_unit (Begins at: 9 Ends at: 46)
Complexity: | 5 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 10 | | OK |
LOC: | 38 | | OK |
metrics are OK
get_proj_desc (Begins at: 48 Ends at: 84)
CalledNBR: | 12 | | OK |
LOC: | 37 | | OK |
metrics are OK
get_proj_parms (Begins at: 86 Ends at: 184)
Complexity: | 13 | | OK |
CalledNBR: | 15 | | OK |
LOC: | 99 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-12-18 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
