[GRASS-QA] GRASS QA: hamish | ./grass6/display/d.title/normal.c |no clones | 0 monsters | 0 warnings
Tue Dec 19 02:51:46 EST 2006
Hello hamish,
ANALYSIS
display/d.title/normal.c functions
normal (Begins at: 4 Ends at: 23)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       9 |       |      OK |
LOC:          |      20 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-19 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
