[GRASS-QA] GRASS QA: brad | ./grass6/lib/gis/adj_cellhd.c |no clones | 0 monsters | 1 warnings
Wed Dec 20 04:50:46 EST 2006
Hello brad,
ANALYSIS
lib/gis/adj_cellhd.c functions
G_adjust_Cell_head (Begins at: 64 Ends at: 201)
Complexity:   |      21 |     * |         |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      15 |       |      OK |
LOC:          |     138 |     * |         |
metrics are OK
G_adjust_Cell_head3 (Begins at: 203 Ends at: 357)
Complexity:   |      33 |    ** | Warning |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      22 |       |      OK |
LOC:          |     155 |     * |         |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-20 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
