[GRASS-QA] GRASS QA: markus | ./grass6/raster3d/r3.out.vtk/parameters.c |no clones | 0 monsters | 0 warnings
Thu Dec 21 09:38:40 EST 2006
Hello markus,
ANALYSIS
raster3d/r3.out.vtk/parameters.c functions
set_params (Begins at: 25 Ends at: 136)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       0 |       |      OK |
CalledNBR:    |      28 |       |      OK |
LOC:          |     112 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-21 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
