[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.proj/main.c |no clones | 2 monsters | 0 warnings
Thu Dec 21 09:56:41 EST 2006
Hello markus,
ANALYSIS
raster/r.proj/main.c functions
main (Begins at: 69 Ends at: 438)
Complexity:   |      27 |    ** | Warning |
CalledNBR:    |     135 |   *** | MONSTER |
LOC:          |     370 |   *** | MONSTER |
2 metric are OUT OF RANGE!
make_ipol_list (Begins at: 440 Ends at: 459)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      20 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-21 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
