[GRASS-QA] GRASS QA: brad | ./grass6/lib/gis/area_poly1.c |no clones | 0 monsters | 0 warnings
Sat Dec 23 05:43:50 EST 2006
Hello brad,
ANALYSIS
lib/gis/area_poly1.c functions
Q (Begins at: 12 Ends at: 20)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
Qbar (Begins at: 22 Ends at: 43)
LOC:          |      22 |       |      OK |
metrics are OK
G_begin_ellipsoid_polygon_area (Begins at: 45 Ends at: 86)
Complexity:   |       2 |       |      OK |
LOC:          |      42 |       |      OK |
metrics are OK
G_ellipsoid_polygon_area (Begins at: 88 Ends at: 135)
Complexity:   |      10 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      48 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-23 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
