[GRASS-QA] GRASS QA: brad | ./grass6/lib/gis/geodist.c |no clones | 0 monsters | 0 warnings
Sat Dec 23 05:43:51 EST 2006
Hello brad,
ANALYSIS
lib/gis/geodist.c functions
G_begin_geodesic_distance (Begins at: 37 Ends at: 45)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
G_set_geodesic_distance_lat1 (Begins at: 60 Ends at: 75)
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
G_set_geodesic_distance_lat2 (Begins at: 77 Ends at: 117)
CalledNBR:    |       6 |       |      OK |
LOC:          |      41 |       |      OK |
metrics are OK
G_geodesic_distance_lon_to_lon (Begins at: 119 Ends at: 200)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      82 |       |      OK |
metrics are OK
G_geodesic_distance (Begins at: 202 Ends at: 207)
ParamNBR:     |       4 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-23 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
