[GRASS-QA] GRASS QA: brad | ./grass6/lib/segment/get.c |1 clones ( get.c )| 0 monsters | 0 warnings
Wed Dec 27 02:39:56 EST 2006
Hello brad,
ANALYSIS
lib/segment/get.c functions
segment_get (Begins at: 24 Ends at: 41)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  segment_get
In lib/segment/get.c clones of  segment_get are:
	lib/segment/put.c  segment_put
Threshold GRASS6 key metrics values at 2006-12-27 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
