[GRASS-QA] GRASS QA: brad | ./grass6/lib/segment/seek.c |no clones | 0 monsters | 0 warnings
Wed Dec 27 02:39:57 EST 2006
Hello brad,
ANALYSIS
lib/segment/seek.c functions
segment_seek (Begins at: 10 Ends at: 21)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-27 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
