[GRASS-QA] GRASS QA: glynn | ./grass6/vector/v.digit/driver.c |no clones | 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Sun Jul 9 18:50:18 EDT 2006
Hello glynn,
ANALYSIS
vector/v.digit/driver.c functions
driver_refresh (Begins at: 10 Ends at: 16)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
driver_open (Begins at: 18 Ends at: 53)
Complexity:   |       2 |       |      OK |
CalledNBR:    |      30 |       |      OK |
LOC:          |      36 |       |      OK |
metrics are OK
driver_close (Begins at: 55 Ends at: 61)
CalledNBR:    |       3 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-07-09 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
