[GRASS-QA] GRASS QA: soeren | ./grass6/raster3d/r3.to.rast/main.c |1 clones ( main.c main.c )| 0 monsters | 1 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Mon Jul 10 14:19:14 EDT 2006
Hello soeren,
ANALYSIS
raster3d/r3.to.rast/main.c functions
fatalError (Begins at: 49 Ends at: 67)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      19 |       |      OK |
metrics are OK
setParams (Begins at: 73 Ends at: 100)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       0 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      28 |       |      OK |
metrics are OK
G3dToRaster (Begins at: 107 Ends at: 177)
Complexity:   |      12 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      24 |       |      OK |
LOC:          |      71 |       |      OK |
metrics are OK
main (Begins at: 183 Ends at: 342)
Complexity:   |      21 |     * |         |
CalledNBR:    |      61 |    ** | Warning |
LOC:          |     160 |     * |         |
at least 1 values are close to an outlier please consider revising code
open_output_map (Begins at: 349 Ends at: 358)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
close_output_map (Begins at: 363 Ends at: 367)
ParamNBR:     |       1 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  setParams
In raster3d/r3.to.rast/main.c clones of  setParams are:
	raster3d/r3.cross.rast/main.c  SetParameter
Threshold GRASS6 key metrics values at 2006-07-10 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
